Transfer Case Switch
I switched out my NP273 transfer case with a used NP271 last month. I felt this was my best option since I have an electrical issue with the electronic shift and the 273 would not shift manually, so therefore since I had to replace it anyway might as well put a manual unit in there.
Slow! Due to the limited space and 4 bolts had to wrenched. I replaced the vacuum hubs with manuals long ago when a new vacuum hub broke again. I could have raised the cab to get more room but to me if I need to remove the cab to do maintenance its not going back on. I'll use the foundation for a more simpler ride. I also had to remove center seat and cut floor out to get access to 2 bolts. Since I had planned on building a custom one in the future that was a no brainer, I just got started early on another project
