Sponsored by: Real Truck
Transfer Case Switch
Old Jan 6, 2017 | 08:29 PM
Dantylr1964's Avatar
Dantylr1964
I switched out my NP273 transfer case with a used NP271 last month. I felt this was my best option since I have an electrical issue with the electronic shift and the 273 would not shift manually, so therefore since I had to replace it anyway might as well put a manual unit in there.
Old Jan 6, 2017 | 09:15 PM
RainDesert's Avatar
RainDesert
That's great, how did the swap go? easy? any issues? Are you leaving the stock vacuum hubs or replacing them with true manual hubs?
Old Jan 7, 2017 | 06:45 PM
Dantylr1964
Slow! Due to the limited space and 4 bolts had to wrenched. I replaced the vacuum hubs with manuals long ago when a new vacuum hub broke again. I could have raised the cab to get more room but to me if I need to remove the cab to do maintenance its not going back on. I'll use the foundation for a more simpler ride. I also had to remove center seat and cut floor out to get access to 2 bolts. Since I had planned on building a custom one in the future that was a no brainer, I just got started early on another project
Akflyboy
Dec 13, 2016 01:44 PM
robbledee
Dec 6, 2016 10:55 AM
BigBlackF-250
Mar 17, 2015 08:25 AM
2wheeltim
Jan 17, 2011 12:38 AM
countryboy1
Feb 2, 2008 10:53 AM
