2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Cameras not working in cold temps?
Old 01-05-2017, 07:53 PM
TX_YJ's Avatar
TX_YJ
TX_YJ is offline
Have a Lariat 350 here. Did a quick search and didn't find any posts specific to this issue with the new model. Best I can tell it only happens when the outside temperatures are right around freezing or below. Basically the screen goes black when you put it in reverse or try to toggle the front camera. I've only had the entire screen not come on once. Shut the truck off and open/closed the door and restarted and it fired back up, again without the cameras working. It seems like they start working after the truck has been operated for a while and warms up.
Is this common during cold weather? Possible bug the dealer needs to look at? It's not a huge issue because Texas winters don't last long. You don't realize how nice all the cameras are on a CCLB until you don't have them! Oddly enough the rear backup sensors do continue to work and beep. Anyway, just though I would share this issue to see what y'all might have to say. Thanks in advance.
Old 01-05-2017, 07:55 PM
daVincidoc's Avatar
daVincidoc
daVincidoc is offline
5 below zero here last few days with highs around 7 above. Cameras work fine. I would get it checked out
Old 01-05-2017, 08:14 PM
Xwild's Avatar
Xwild
Xwild is offline
Camera has worked fine every day so far, and it's running in the low teens here.. Snow tends to cover the tailgate cam, but that's about it...
Old 01-05-2017, 10:03 PM
firechicken92's Avatar
firechicken92
firechicken92 is offline
Your not alone. I'm a month in and it's happened to me three times on freezing mornings. I can say a master reset on the head unit also brings them back up if you are in a hurry for them to work.
Old 01-05-2017, 11:13 PM
ysgi's Avatar
ysgi
ysgi is offline
no problems here above, at, or well below freezing.
But as someone else said. I have had snow and ice on some of the cameras that basically render them useless.
ysgi
Old 01-06-2017, 09:38 AM
PwerStroke99's Avatar
PwerStroke99
PwerStroke99 is offline
I have had the same issue at times, it has been at 0 or below the last several days. It starts working once I park it and it sits in the garage for a few minutes. Im not too concerned, unless it completely stops. Hard to troubleshoot something that is intermittent.
Old 01-06-2017, 10:20 AM
jdunk54nl's Avatar
jdunk54nl
jdunk54nl is offline
I don't know if this is related but I know a lot of aftermarket LCD head units do have limited functionality when they are too cold. A few aftermarket head units I used to have had them listed at anything below IIRC 20 degrees Fahrenheit will result in limited functionality with minimum operating range around 0 degrees. I know the temp was higher than I expected it to be but ran into it a few times even living in Arizona the past few years. Ran into the temp limited function a lot in Michigan. This will depend on where the truck is stored and is also dependent on what the head unit deems as too cold.
Old 01-06-2017, 01:12 PM
TX_YJ's Avatar
TX_YJ
TX_YJ is offline
This is my fear if/when I take it to the dealer. It will probably work flawlessly...
Old 01-06-2017, 09:54 PM
coolidge54's Avatar
coolidge54
coolidge54 is offline
I have a Lariat with the fancy camera tow package. Its been 17 to 25 here for a while and no issues with the cameras at all due to cold weather.
Old 01-06-2017, 10:13 PM
Sleepyguy's Avatar
Sleepyguy
Sleepyguy is offline
I think it needs to be bellow -20 before the cold effects electronics. Mine has never had cold related problems just electrical issues and lots of them. I believe ford built me a lemon.
My 08 f350 backup camera never failed in any cold. -40 no problems. And that is over 7 years.
NORTHLAND06
01-29-2018 06:17 PM
IABill
01-21-2018 08:43 AM
Billyclub
21
01-14-2010 09:49 PM
mechmagcn
Arkansas Chapter
01-10-2010 08:33 PM
kinchley
1999 to 2016 Super Duty
11-29-2004 11:39 PM
Quick Reply: Cameras not working in cold temps?
