390 starter bolt size
The starter puts a lot of twist on the bell housing. I am not smart enough to know how helicoils stand up against the twist. Methinks that they are for static problems like manifolds and water pumps. So methinks redrilling and tapping oversize would be a better solution. Hogging out starter holes should not be much of a problem if you have ability to drill and tap.
I believe that once the bolts are torqued down the mating surfaces of the bell housing and starter case transfer the torque to one another and the sheer load on the bolts themselves would be minimal.
The holes in the starter/spacer/seperator plate are already large enough for 3/8 hardware.
I went ahead and installed helicoils. They went in without a fight, which was odd.
Studs aren't a bad idea.
If you are concerned with a helicoil loosening up from vibrations, I doubt they will. I would be more concerned about them backing out when you remove the bolt. Just use some high temp thread locker. I repaired the threaded starter bolt holes on my I-300 using a helicoil. It worked perfect.
AZRRC
01-21-2014 12:11 PM
greystoke33
02-14-2003 08:18 PM
