Updating brakes
#31
Thanks, Eric. This is the single reservoir (suicide) MC that was on the '65 F100 before I changed it out for the tandem MC 7 or 8 years ago.
This is the setup I installed on my own '69 F100 Ranger back in October, 2014.
This is from my most recent work (back in September) that I did on another friend's '72 F100 Sport Custom.
#32
Steve,
Your friend is lucky to have your help! You did really nice/neat work on those brake lines.
Q1) How do you make your tight "vibration dampening' loops (as you did on the '72 Sport Custom and the '69 Ranger)?
Q2) Why didn't you bend up any loops with the '65 setup?
Q3) What model year is the cast-iron dual reservoir MC installed on the '65?
Q4) I agree that it looks sharp, but isn't the outer 'spring wrap' primarily/technically usually installed over brake lines for protection purposes - why have it up by the MC?
BarnieTrk
BarnieTrk
#33
Steve,
BarnieTrk
BarnieTrk
A1) I made the loops by bending the tubing around a deep well 15/16" socket.
A2) For a number of years, I didn't put loops in the tubing. Often times, it was difficult to get the fittings to line up straight to the ports to get them started. The loops make it easier to have some flexibility to get the fittings started and to reduce the chances of work hardening the flares at the ends of the tubes due to vibration and road shock.
A3) That was 7 or 8 years ago when I put the MC on the '65 F100. My friend supplied all the parts. I just put them on and fabricated the lines but, I want to say the MC was for a '78 F150 (since the front discs installed on the '65 F100 were from a '78 F150).
A4) The Spring Wrap/Armor Guard is for the purposes of protecting the hard lines from rocks/road debris. It will also act as a heat sink (like fins on a valve cover) to help dissipate heat soak into the brake fluid from underhood temperatures plus, I think it just looks cool.
#34
#35
I purchase it through Classic Tube in 3/16" OE steel. For more money, you can get it in stainless steel too.
Classic Tube
#38
I was just under the truck to look for the little block that distributes fluid between front and back on these trucks. Seemed to me a larger distribution block from 67 and up may not fit in where the original is due to size and access.
One, where is the block in a 67 and up truck? Two, if not possible where else could this block be mounted as it already has a bracket and two mounting bolts.
#39
This on a '72 F100.
#40
I thought so and it is already tight with the little block in there. I am strongly considering getting at least the three brakes lines already made for the 67-72 years. That leaves me with only having to make the two lines out of the master rather than trying to synchronize all five to the exact same place.
#41
TwistedFate
04-15-2015 12:00 AM
