Width of 1970 9" rear
I would like some help guys on the measurements of the 1970 f-100 rear end . On an article here on fte I found the measurements for the nine inch to use it says to use one that has a width of 61 inches from axle flange to axle flange now does that mean the axle housing flange that the axle bolts to or does it mean the flange that the wheel bolts to ? I get a 56 1/2 from axle housing flange to axle housing flange. I have everything torn apart for cleaning and rebuild so I did not have the axles in guess I need to slide the axle back in. I did not see the truck that this came. Thanks and hope all had a Merry Christmas.
If you are still not sure (as is the case with me on most of these measurement) take a picture with a tape measure at the various places you have flanges and then the guys that know can tell you pic 1 showing x inches or pic 2 showing y inches or pic 3 showing z inches is the correct measurement. Works best for me and these guys are great at answering a well thought out question.
The following users liked this post:
There are 2 different 9 inchers, most of the parts do not interchange!
1) Standard equipment: 9" with 28 spline axle shafts.
2) Optional: 9" w/a 9 3/8" ring gear, 31 spline axle shafts and 4 pinion Traction-Lok (Limited Slip).
.fordification.com/tech/rearends_ford01.htm Bill this is the link that I found it on. Also thanks for finding me the parking brake cables I got them in the Kansas City area they are new repos made here in the U.S.A. Happy New Year to you and yours and talk to you in the new year. Happy New Year to all on this site and thank all of you for your help. Have a very satisfying new year.
Do u know the part number for the 28 spline wheel bearings
Same: 1968/72 F100 with 11" x 2 1/4" rear brakes, but...
Sleepy_Dave
09-19-2010 03:57 AM
