Squeaky belt
Old 12-22-2016, 04:29 PM
kyle j's Avatar
kyle j
kyle j is offline
Originally Posted by oldbird1965
This was mine, there are no compressed parts that I remember.
woah yea that's toast. I just tried a oil wrench couldn't get enough bite I dought I'll get a strap on it. Also tried jamming a screw driver in but nothing really to bite
  #32
Old 12-22-2016, 04:56 PM
kyle j's Avatar
kyle j
kyle j is offline
if I replace the whole compressor and I don't use the Ac am i right to assume it won't harm the new pump if there's leaks in the system? Also can I remove the lines connected to it without getting the whole system evacuated?
  #33
Old 12-22-2016, 06:43 PM
kyle j's Avatar
kyle j
kyle j is offline
@knottyrope
  #34
Old 12-22-2016, 06:48 PM
farmert's Avatar
farmert
farmert is offline
If you remove the lines you will loose the refrigerant. Any time the system is opened, you should pull a vacuum on the system to get all moisture out. Use an impact wrench to remove the center bolt, hit it with short, quick blasts. It sounds like the system is low on refrigerant if the clutch won't lock the clutch with the key in the run position, and the control set to air. If it has a low charge the low pressure switch won't let the clutch kick in. Usually the center part of the clutch has threads in it to pull that part off the shaft. Remove the center bolt, and thread a larger bolt back in the center. the bolt will hit the shaft and force the center part of the clutch off the shaft. Behind the center part that you just removed will be a snap ring holding the outer part of the clutch with the bearing on the nose of the compressor, which is lightly pressed on. The magnet is behind the part you have just removed.
  #35
Old 12-22-2016, 08:06 PM
kyle j's Avatar
kyle j
kyle j is offline
thanks for the reply, Finaly got it off with a second pair of hands and some good old merchanical advantage. Is it nessassary to replace the inner clutch coil? Only asking cause that would require buying more tools (pully pulled and press) and I'm on a budget right now
  #36
Old 12-22-2016, 08:08 PM
kyle j's Avatar
kyle j
kyle j is offline
  #37
Old 12-22-2016, 08:22 PM
farmert's Avatar
farmert
farmert is offline
I'd replace the coil, as I have had them get weak on my tractor, and not pull and hold the clutch together. The coil is not that tight on the nose of the compressor. A couple of screw drivers behind the coil should lever it off. A dead blow hammer should tap it back on.
  #38
Old 12-23-2016, 08:27 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
I have replace compressors before and not attach the coil wire until I could get it vacuumed out.
  #39
Old 12-23-2016, 01:57 PM
kyle j's Avatar
kyle j
kyle j is offline
Got it all back together and still sqeeking loud I'm at a loss . Figured I had it norrowed down for sure since when I sprayed the Ac pully with wd the sqeeking went away for several seconds then came back. Any ideas?
  #40
Old 12-23-2016, 02:04 PM
knottyrope's Avatar
knottyrope
maybe your pump is bad?
Did you spray the pulley or the belt or both?
Some squeaks can be a pain to find
  #41
Old 12-23-2016, 04:36 PM
kyle j's Avatar
kyle j
kyle j is offline
went on a hunch and threw my old serpentine belt on and so far so good noise is gone! Wounder why my new dayco belt that I put on less than 7 months ago was making that noise? Didn't notice and major defects other than it was a bit looser than the old one
  #42
Old 12-24-2016, 07:36 AM
knottyrope's Avatar
knottyrope
Loose belts squeal
  #43
Old 12-27-2016, 12:55 AM
coreyallan01's Avatar
coreyallan01
coreyallan01 is offline
I have the SD Idler and once a year I have to replace the belt because it starts to squeak...
  #44
Old 12-27-2016, 08:12 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
Maybe one of your pulleys is not aligned with the others causing the belt to wear out and start to squeel.
FactoryNewGarbo
1997 - 2003 F150
08-17-2016 10:37 PM
stefanwest
1983 - 2012 Ranger & B-Series
10-25-2014 07:38 PM
X_man
09-17-2009 08:34 PM
redwolfhopw
04-13-2008 12:44 PM
Quick Reply: Squeaky belt
