1000+ HP from Junkyard 351w.. Pretty Cool!
Old 12-14-2016, 08:18 AM
kjemison's Avatar
kjemison
kjemison is offline
8th Gear
Just thought this was pretty interesting. I would have never guessed that a stock lower end with 2 bolt mains would take this much abuse! ... Also, on this engine with the boost set to only 7 psi on the turbo, they were able to get up over 600 HP! ... The motor finally gave up when the boost was up to 21 psi or so... Good read though! Check it out... How to Push a Junkyard 351 Windsor Past 1,000 HP! - Big-Bang 351W
Old 12-22-2016, 07:31 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
And people say only the GM LS engine can handle this! Forced induction is a beautiful thing!
Old 12-23-2016, 06:41 AM
Mudsport96's Avatar
Mudsport96
Mudsport96 is offline
The Windsors are strong, and the 351M has impressed me before as well. There used to be a guy locally that had a 78-79 Bronco with an M in it that mud raced. It was his daily driver it was all rusted out and leaked fluids everywhere but ran good. He ran hot stock since he had headers and an aftermarket intake and Holley. And also hot modified because of the nitrous he would run on it for that class.
I talked to him a few times and he said the only "real mods" were the intake,nitrous and Rv cam. The heads he claimed were ported by pulling the valves and sucking sand from his kids sand box through the ports with a shop vac.
It ran well in stock class he would usually finish top three unless someone from out of town would show up with a ringer.
But man did that thing run on the bottle in hot modified. There is no sound like 250 horses just showing up at the push of a button. First or second always, and if he took a loss on the first round of double elimination he'd have the hood up swapping jets for the second round and be flying out of the end of the pit on the second pass.
​​​​​​​I remember on year he said he thought he hurt it because it started running 7psi of oil pressure at idle and 10psi at 1500rpm. But he drove it for two more years like that lol
Old 12-23-2016, 04:22 PM
Pkupman82's Avatar
Pkupman82
​​​​​​​Yeah a lot of people automatically dismiss the 335 series motors as boat anchors. I know a couple guys out here that had 400s that were worked over, and boy did they run! Most people thought they were 460s. My wife has a worked over 351m in her 77 F150, not entirely sure what has been done to it. I'd like to make a screamer out of it some day. Yeah the whole oil pressure thing, haha I swear oil pressure must be an optional thing with Fords. I have a sweetheart of a 460 in my Bronco that gets crap oil pressure. I beat the crap out of that thing, doesn't seem to phase it and that thing rips! I've always been impressed with the durability of the Windsor V8s, they run forever through the worst conditions. My father in law is running a 90 F150 with the 5.0L, it's had a blown head gasket for almost 2 years. He sealed it up with black pepper, it just keeps going!
Old 12-25-2016, 09:07 AM
Mudsport96's Avatar
Mudsport96
Short of the newer 5.0 blocks that just about everyone knows are HP limited, most engines can make big numbers. Especially on boost as it doesn't shock load like the Bottle does. And junkyard engines are good for the fact the rings are seated and have a decent gap if they are over 80,000 miles. As long as you keep the detonation away and done miss a shift or blow the spark out and unload a cylinder they can handle more than the average person would think.
Shadow944795
05-28-2014 05:51 PM
oldbird1965
51
03-17-2014 09:21 PM
anotheraggie
43
10-15-2013 08:17 AM
l-m tech
07-06-2012 07:51 AM
401477534
Oil & Lubrication
15
07-30-2011 09:06 AM
Quick Reply: 1000+ HP from Junkyard 351w.. Pretty Cool!
