Adding Cab lights
Adding Cab lights
Anybody ever add cab clearance lights to a truck that didn't have them? Any tips or suggestions on where to buy? My stepson is looking to add some to his 06 crew cab and I don't know about what wiring is in the truck now and there is a butt load of aftermarket options. Standard incandescent bulbs would be ok, just need them to fit right and not leak etc.
There was a good thread on this a while back. He can get a harness from Ford, or a couple of after market places. They should be plug and play in the side kick panel on passenger side.
Recon is one place to get them from.
Check this write-up.
F250 Factory Clearance Light install
I would go on ebay and find a set of OEM Ford lights. its pretty easy to find a take off set with all 5 bases, covers and wiring harness. I would not trust any aftermarket light (especially recon) to not leak, or burn out quickly. As for install/wire plug in location, there is a writeup on here somewhere, ill have to look
If using used ones I'd use a mild sealant. It is quite common from age for them to leak and reek havoc because most people never know. the water will come down the A-pillars and run into the dash and harness. Sometimes wind shields are blamed but it ends up being leaky cab lights.
The stock light is just a simple Truck Lite brand light, if he is looking for a stock appearance this is it, I bought mine at my local Peterbilt dealer cheaper than I could find anywhere else, JMO.
25 Series, Mini Aerodynamic, Incandescent, Yellow Triangular, 1 Bulb, Marker Clearance Light, PC, 2 Stud Mount, AMP 174928-1, 12V | Truck-Lite
FYI.
FYI.
I would look for a reputable aftermarket set of leds, im sure someone knows a good brand on here, then take every possible step to avoid leaks. grommet the hole if possible, use silicone around the hole inside and out, IMO its better to be safe than wet. As far as measurements its personal preference if you want then evenly spaced or set like they are from the factory
I have installed cab lights before and never had an issue with leaks, but I would never do it again, I was very worried about them being perfect way to stressful for me LOL
I used the recon lights and the only issue I had was the LEDs burned out they sent me out new ones right away and all was well.
Id rather pay someone to do it again, but if you do end up doing it, post up some pics my buddy just bought a truck that doesn't have them and he wants to add them
Ravenwood Ranch
01-02-2010 10:00 PM
