Just got it apart today. The bolts are 9/16" that go into a 5/8" hole in the bushing. Kind of a loose fit but that is how they all are.
Were two of the bolts tied together by a strap shaped bracket? They are supposed to be. Once Bill catches my request for him to post a pic on your other thread you'll see what I mean.
Yes. 2 bolts are tied together and one is separate on the rear. The front bolt is separate too. Total 4 bushings per side.
The two bolts have to be tied together. Are those what you're looking for? The two bolts tied together by that bracket was part number C8TZ5776A. Left and Right side the same. This place has two of them:
Part Number:C8TZ-5776-A
Seller Dennis Carpenter Ford Restoration Parts
Description:NOS** REAR SPRING SHACKLE
Phone (800) 476-9653
Price:Request PricingEmail:Send Seller Email Inquiry
My double bolts are fine. I need the part number for the single bushing bolts.
The part number was originally 56215-S2 front and back for a F100. That was replaced by 56615-S2. Discontinued. None on my locators.
I quote myself from your other thread:
What's in there now may be 9/16" but if the I.D. on a bushing is 5/8" then that is the bolt size I would use. If it were me I'd go to H.D., Ace, or a local nut/bolt store and buy some grade 8 5/8" bolts. Install them covered in never seize.
