Computer delete 84 f150
Old 01-22-2017, 12:27 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,685 Likes on 1,361 Posts
Won't turn over or won't fire off?
Old 01-22-2017, 12:50 PM
Brandokendall's Avatar
Brandokendall
Brandokendall is offline
Ok sounds good. So yes the choke is fully open and the issue is it won't turn over fast enough to start. Sounds like a dead battery. But give it 20 mins or so and it fires up perfectly
Old 01-22-2017, 12:55 PM
Franklin2's Avatar
Franklin2
The timing is too advanced. Turn it back a little bit till it turns over better hot.
This can also be caused by springs that are too weak or missing on the centrifugal advance under the rotor cap. You can check that, take the dist cap off and then grab the rotor and twist it and let go. It should go back to it's home position with a snap. If it's stuck or sluggish, take the rotor off and see what's going on underneath.
Paul270
05-09-2010 07:26 AM
ole rusty 84
04-30-2009 11:58 PM
six-banger
04-19-2008 03:02 PM
'78 Custom
11-05-2005 11:16 AM
BMW2
Bronco II
10-18-2004 02:56 PM
Quick Reply: Computer delete 84 f150
