High brake light wiring
Old 11-26-2016, 04:48 PM
rjniles's Avatar
rjniles
rjniles is offline
I bought a used ARE fiberglass cap for my 2014 F150. I has a high third brake light that I would like to connect. Doing some on-line searching there seems to be a unused green wire in the wiring harness that supplies power for the third brake light. Various descriptions say it is taped to the wiring harness on the drivers side frame rail any where from next to the spare tire to under the drivers door.
I have done a lot a crawling but am unable to find this elusive wire. Anyone know where it is actually located on my truck?
Old 11-26-2016, 08:31 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,684 Likes on 1,360 Posts
Look at page 4 3rd column over in this link.
https://www.fleet.ford.com/truckbbas...iring_v1-0.pdf
They say the only wire you should use is near the rear bumper/frame area in the trailer tow blunt cut wires.
Old 12-01-2016, 01:48 PM
rjniles's Avatar
rjniles
rjniles is offline
I have given up finding this elusive CHMSL connector and have gone a different route.My F150 has both a 4 pin and 7 pin trailer connector and I only use the 7 pin. I plugged in a 4 pin trailer side connector and ran the leads up behind the left tail light. This gives me left turn, right turn, parking light and ground. I connected the right and left turn to to the cap brake light with diodes in the circuit so the left will not cause the right to flash and vice versa. Connected the ground also and viola. High brake light without cutting into any wiring harness. The light will also flash when I use either turn signal and goes steady when I touch the brake. I understand this may be illegal in some states.
I also ran parking light and ground back down to my rear license plate mounted wireless back-up camera. This lets me turn on the camera by turning on the parking lights. I could easily connect this lead to the back light instead for automatic operation
All the splices are behind the left tail light and all I have to do is pull the 4 pin connector and it is all disconnected.
xjpilot
29
04-02-2017 06:46 PM
Lebowskii
09-01-2011 03:23 PM
vol1966
02-20-2011 11:01 AM
boeingoing
1999 to 2016 Super Duty
02-09-2010 02:38 PM
schpifford
Electrical Systems/Wiring
11-03-2008 11:09 AM
Quick Reply: High brake light wiring
