Headlight Problem 96 F150
I have a problem with my headlights. When I turn off the motor the lights stay on. I have to unplug them from the bulb so as not to kill battery. Also notice that the motor will not turn over sometimes when the key is turned to start position . Usually after several tries it will start. Any info will be appreciated.
Thanks
Ron ( Nova Scotia )
Thanks
Ron ( Nova Scotia )
Yes, my truck has the same DRl system.
I assume that you are talking about the dash mounted pull out switch.
Is there a fuse for the headlights? It would make it easier for driving over the holidays until I get it fixed at dealership.
Also I thought there may be a link between the "key" problem and the "headlight" problem.
Thanks RON
Thanks RON
I have an automatic, extended cab. All the other lights, dash indicators are OK. Also just before this problem I had my brake light come on. Checked everything and brakes were fine. The brake light would go out when I put my high beam on when driving. After a week or two the brake light problem went away and was replaced by headlight staying on.
Thanks Ron
Thanks Ron
