1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Headlights
Old 10-25-2016, 10:00 AM
Medic 66's Avatar
Medic 66
Medic 66 is offline
Headlights
My 99 F250 NBS truck has 259,000 miles and my headlights (original of course) on both sides are so dim they are practically useless. Is the problem the outside plastic or the bulb filament units mounted in the plastic? The plastic feels a little rough when you rub it, but it is not clouded over real bad like I have seen on some other cars. Are you supposed to be able to look inside the light from the outside and see the filament?
Thanks
RC
Old 10-25-2016, 02:23 PM
bleeds blue's Avatar
bleeds blue
bleeds blue is offline
I had the same problem with mine. I replaced them with Eagle Eye lenses. I believe anyway. They were only about $70 and came with new bulbs as well. They are clear as can be.
Old 10-27-2016, 11:08 AM
Medic 66's Avatar
Medic 66
Medic 66 is offline
Do they do a good job at night? Would you do the same purchase again?
Old 10-27-2016, 12:28 PM
scraprat's Avatar
scraprat
scraprat is online now
Received 2,496 Likes on 1,305 Posts
Now this wont totally rejuvenate the lens but if you have "OFF' the bug spray, spray some on a rag wipe the lens it will clear them some but wont make it like new. wipe and repeat.
Old 10-27-2016, 01:16 PM
Medic 66's Avatar
Medic 66
Medic 66 is offline
I recall seeing some type of cream looking stuff that AutoZone had that claimed you can put drops on a brush thing and attach it to a cordless drill and run them over the headlight plastic.
Those things worry me about eating away the plastic and having a hole. "OFF" sounds less dangerous.
Old 10-27-2016, 07:17 PM
bleeds blue
I tried using the lens restore. Nothing more than a fine polishing compound. Looked great for about a week.
The new lights are brighter than the old ones. I would not say they are great though. I have an E99 so I dont have the running lights. REALLY wish I did. I would say they did more for the trucks looks than they did light output. I put the most expensive Sylvania bulbs in it I could buy.
Old 10-28-2016, 05:16 AM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
There are videos on YouTube where toothpaste was used to polish a yellowed headlight lens.
Old 10-28-2016, 06:44 AM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
Go to 1Aauto and buy a new set of lens casings. Really cheap. I did the whole front of my truck including the fog lamps for under $200. Problem solved. I did the rub thing with toothpaste and lens cleaner and the like. Still comes back.
Gousetis
22
10-06-2020 12:45 PM
curtis73
03-10-2012 10:10 PM
Bad Company
Appearance & Dress-Up
05-09-2010 06:12 PM
allisonmo2
20
03-19-2009 09:15 PM
rpatrick
1997-2006 Expedition & Navigator
03-19-2007 11:00 AM
Quick Reply: Headlights
