Sponsored by: Halo Lifts
Towing
Old 10-24-2016, 09:36 AM
cdmm151's Avatar
cdmm151
cdmm151 is offline
Towing
Beginning the process of looking at rvs. The question is anybody tow the lightweight fifth wheels with the F150? What rv is it and how is it handling?
Old 10-24-2016, 01:50 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
OP...that is a good question. Joining the thread...
biz
Old 10-24-2016, 04:18 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
How lightweight? Something like a 19' Scamp? Those are super light (around 3000# IIRC), and you could tow with an old-style Tacoma.
We pull a 20' R-pod, and it is like nothing behind our F-150. I think it's about 4300# with a full load.
Old 10-24-2016, 09:14 PM
djjoshuad's Avatar
djjoshuad
djjoshuad is offline
I think unless you have the 8' bed, a 5th wheel is going to be an unnecessary headache. even with a 6.5' and a shortbed-friendly cap on the trailer or a slider hitch, I'd still opt for a bumper-pull. The biggest benefit of a 5th wheel is that it positions the pin (hitch) weight over the axle. Too much weight on the bumper can create real problems but with super light loads, that's a non-issue. IMO unless you're looking to tow over 5000 lbs, bumper pull is the way to go.
Old 10-24-2016, 09:31 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
X2. Easier and simpler. I pulled a 5k bumper pull with a Ranger (4.0, manual, 4.10s), a new F150 wouldn't tell it was there.
The biggest problem is king pin weight. A lot of F250s pulling 5vers are technically overloaded on paper, but the margin of safety is still there because the main components (frame, brakes, driveline, tires) are basically the same between F250s SRW F350s. RV weight tags are very, very skimpy compared to what the real weight can be, unless someone can show a scale ticket never trust what they say they're running for pin weight. 1/2 ton towable 5vers exist, but the pickings are much more slim simply because of design and the higher pin weight they carry versus tongue weight on a bumper pull. Some literature says 20% pin weights, but 25% is closer to accurate for a lot of designs and how people load the trailers. That 5% difference is 450# on a 9k trailer, pretty easy to sail past the F150 ratings where the wheels and P-metric tires don't have the same leeway as E-Rated tires on an SD do.
Step #1 is something most people don't bother with, and that's weight the truck itself to see what you even have to play with. Payload guide for 2016 attached:
Old 10-25-2016, 12:31 AM
McObra's Avatar
McObra
McObra is offline
There are fifth wheels which are, in theory, 1/2 ton towable. You would have to know the pin weight of the trailer and the load capacity of your truck, both to support the pin weight and to pull the weight. You also need to take into consideration the weight of your passengers, luggage, fuel, etc. and everything else you will carry in the truck.
Old 10-25-2016, 09:00 AM
onug's Avatar
onug
onug is offline
I've got a 5.5' bed and I had 1,500lbs of remaining capacity over the rear axle when I first bought the truck (weighed on a truck scale, just me in the cab, no gear loaded). Lot's of people tow with a 6.5' bed, but you'll lose another 100lbs (if I remember correctly) going with the longer bed. Add in the weight of a hitch and gear, and you're quickly approaching 1,000lbs remaining capacity. I don't have a trailer now, but have in the past, and agree with the 20% pin estimate. I was a weight-nut and scaled my system (31', 9,200lb pumper-pull) at least once a year. It's very,very easy to add 1,000lbs of gear without looking. At least it was for my family of four.
Something else to consider is many people complain about how quickly these current gen trucks squat under the weight, so you may also need to add some kind of suspension assist gear (that's a separate conversation...mild to wild). I've got 600lbs of gear in my truck (canopy, gear, Decked system). I've down to a 1" rake now; basically leveled, and she drives like an old Cadillac when loaded for the weekend.
Old 10-25-2016, 10:33 AM
djjoshuad's Avatar
djjoshuad
Unless someone designs a trailer specifically to work with the 5.5' box, a 5th wheel is basically out of the question. There just isn't enough room for the cap to clear the cab when turning. even with 6.5' ones, you need either a slider hitch or a cap that is designed for short beds.
An add-a-leaf for about $150 or some airbags for a little more will fix that
Old 10-25-2016, 12:33 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Or 1.5" thru 3" rear blocks by ReadyLIFT would also work. Personally, I would go with Airbags if I towed that heavy.
biz
Old 10-28-2016, 10:02 AM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
We hauled about 1,700 lbs of flooring the other day. You could feel the load, but the truck really didn't squat all that much; it was only slightly out of level.
Hauling our TT, the WDH took care of getting things level. If our TT was heavier, I'd certainly do air bags or aux springs.
Old 10-28-2016, 05:48 PM
GuyGene's Avatar
GuyGene
GuyGene is offline
I like travel trailer because of weight distribution hitch. Fifth wheel puts all weight on truck hind end. We have our third trailer now.
jimcam48
EcoBoost (all engine sizes)
29
03-02-2012 03:54 PM
E350turbo
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-27-2004 05:28 PM
PSKSAM2
1983 - 2012 Ranger & B-Series
10-14-2003 06:27 AM
TBible
Fifth Wheel & Gooseneck RV Towing
07-02-2003 04:40 PM
DeenHylton
10-01-2002 05:31 PM
Quick Reply: Towing
