electeical question
electeical question
Its been while since I have been on here the summer here was miserable So now im working on my truck again
Im switching from the old round style ( for an 82 F100 ) vacuum switch for the climate control with
a square connecter ( seen on the right ) to a newer switch.
there are 2 brown wires with white stripe
one brown with orange stripe and
one green with barber shop stripes
so my question is what order do the go in the red the plug on left
in the photo
This is your A/C mode switch. My diagram does not show the connector positions. All I can tell you is the brown/orange wire is the hot wire from the fuse box. The lightgreen/pink wire leaves the switch to feed the low pressure switch and then the clutch for the A/C compressor. I can't figure out what the two brown/white wires do, they are spliced together in the harness. Maybe I will go to Gary's site and see what he has on it.
According to this diagram I am wrong in the post above.
The hot wires are the brown/whites. The brown/orange goes to the blower and feeds it so it runs all the time with the a/c on so it won't freeze up. The Lightgreen/pink is still the clutch for the compressor. I don't see a connector reference in this diagram either, so you will have to take a meter and probe the connector to figure out whats what.
P.S. It says "see page 100 for switch terminals" in the diagram. I don't know if Gary put that page up or not.
I appreciate your help on this. the 82's to 83's I think there may been two different style first being the square type, i'm not certain of this. But any way knowing what wire goes to what is a big help thanks for the help. When I get it hooked up maybe tomorrow will get pics. Thanks again
Oldschool1962
05-14-2012 08:51 AM
ta2rob
09-06-2011 12:56 AM
77 ford shortbed
10-24-2008 07:40 PM
