paging numberdummy
Old Oct 24, 2008 | 05:47 PM
77 ford shortbed's Avatar
77 ford shortbed
Smile paging numberdummy
Hi its joe with the ac wire problem so I can get this relay at green sales co. can I get everything else there also. not to good with wiring so here goes. #883 wire orange comes directly from the battery goes to normally open side of the safety relay.do I have the #268 red and black already in my truck. and does the #753 yellow and red go to the ac mode switch. and do I have the yellow and red wire in my truck already. can I get these wires at green sales co. pheww finally got that one out.
Old Oct 24, 2008 | 07:40 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Well, I'm not Numberdummy, but I can help you a little.
You do not have #883 orange, or the #753 yellow/red wire in your non/ac truck.
#753 Yellow/Red does indeed go to the a/c mode switch, or rather, it comes from the a/c mode switch and goes to the Safety relay.
You also do not have #348 Green/white wire either. This one goes from the A/C mode switch to the A/C evaporator Thermostat, then changes to #347 Black, to the A/C clutch solenoid.
You do have #268 Red/Black, but it is wired differently for a/c. This is explained in the other thread in better detail.
You do have #181 Orange coming from the fuse panel directly to the heater blower switch on non/a/c trucks. On A/C models it will go to the A/C mode switch instead.
The A/C harness in question is plug and play according to the diagrams I have.
All you need to do is get one off of a 1975 through 1977 Ford Pickup with A/C. (1973-1974 1978-1979 are wired differently according to the diagrams.)
Didn't your donor vehicle have this harness?
As for getting a whole A/C harness new, I'm not too hopefull, but numberdummy might be able to help further.
Catchog
15
Apr 14, 2016 03:44 PM
D & D
Sep 18, 2014 08:14 PM
LARIAT 85
Sep 24, 2008 01:24 PM
BaronVonAutomatc
17
Apr 30, 2007 12:04 AM
Awsum77
Jun 18, 2005 10:38 PM
