and the new guy needs help...
I'm trying to get a new heater core for my 1952 F-1. Here is what I took out the other day. I'm hoping someone can point me in the right direction. All my time on the internet has so far produced nothing. I have no idea how long this one has been in the truck. I can't imagine that it could be the original one at all... but I have no recollection of every changing the heater core and I've owned the truck since 1981. Thanks for any help!
If you have a local radiator shop, sometimes they can do a measurement and cross you over to a new core. They will reuse the end section with the tubes and they should also be able to replace the tubes. My cost was around 50 dollars total. One problem with this is there are not very many true radiator shops still around.
core
Did you find a core yet ? That core is 2 " thick & must be precise on the width & length . If you still do not have one ( $190 @ mid fifty whoa ) get in touch . Those are the hardest to find & the headers / tanks are 2 pcs. Am about to take all the components to the radiator shop where the '51 & '52 Magic Air heater cores are made up &see if he likes a challenge .
Your picture is of an original heater core out of a '48-'52 Standard box type heater w/ block lettered FORD .
If it was mine, I would take it to a local shop and try to have it repaired.
My 1987 F250 had a great heater in it, you could drive through the mountain passes with snow on the ground and have to turn the heat to a medium setting. It really worked well.
Then the brass heater core went bad and started leaking. I picked up a replacement from a local parts store. It was some thin aluminum piece made in china. That heater never blew hot air again.
I swear the air from the vents was just starting to blow warm, then it would blow cold again, a few min later almost warm and then cold again.
Was a daily driven work truck and the radiator, water pump T-stat was all new, I drove another 5 years with no heater after that.
This was New Mexico and AC was more important then heat.
Careful of replacement cores.
I have another post on this exact issue. I pressurized my heater core and stuck it in the sink. The bubbles were coming from the solder joint at the tank to core. Local radiator shop said $30 to solder it.
I also got a reply from another member about a substitute core. It is from a 1996 up Ford E-350 REAR heater. Part number and info in that post today. Many are aluminum but, I found one in brass for $30 on eBay.
The only heater core that is the same 1948/56 is 8J-18476-B = 1948/52 F3/F5 Parcel Delivery & 1953/56 P350/500 P Series Parcel Delivery.
minnesota68
02-08-2019 08:37 AM
OneTraveller
03-01-2018 05:33 AM
Norton72
11-18-2014 09:28 AM
DCRB
Aerostar
16
04-25-2008 07:17 PM
