Remote door lock module?
I added the factory module to my '95 so that I could have a key fob and the keyless entry buttons on the door.
I use the buttons for entry a couple of times a week now that I have them.
If you aren't interested in the buttons, then you are correct that aftermarket is probably easier to install and will no doubt have much better range.
Kevin
Kevin
I guess to be fair to anyone else who finds this post with the same questions:
This is what the factory RKE (Remote Keyless Entry) module looks like. The large 5 digit number is the code for the buttons on the door.
This is where it is intalled by the factory in an OBS truck. Behind the pocket in the knee panel below the steering wheel.
This is all the wires released from the harness that I harvested from a 1995 Taurus to put in my truck.
This is a pic of the install. The module can barely be seen in the hole at the top of this pic.
This is a pic of the keypad buttons at night.
All due respect to alberta 7.3 at the .org for his easy to follow write up to do this.
Kevin
Kevin
The following users liked this post:
Good luck.
Kevin
Zach1008
08-15-2018 09:04 PM
Fefanatic
1999 to 2016 Super Duty
03-27-2018 02:33 PM
