inline 6 to a coyote 5.0
Old 09-30-2016, 08:15 PM
hunter ashwood's Avatar
hunter ashwood
hunter ashwood is offline
i have a inline 6 in my 1991 ford f150 and wanting to go to a coyote 5.0 im just wandering what all ill need to do so (im saving up for a crate)
Old 09-30-2016, 11:06 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
Welcome to FTE.
"If you have to ask...."
You will need a transmission to go with it, and an aftermarket controller.
There are links here to get you started, and this is also in the 5.0 Coyote engine forum, where you will have better luck finding other owners and current swaps etc.
https://www.ford-trucks.com/forums/1...ch-folder.html
Old 09-30-2016, 11:10 PM
hunter ashwood
Originally Posted by 85e150six4mtod
Welcome to FTE.
thankyou for the info do you have any suggestions for a tranny i dont know them all that well to be honest
Old 09-30-2016, 11:23 PM
85e150's Avatar
85e150
The Coyote motor uses the same bell pattern as the earlier modular engines. So any trans from one of those would work, although you will be on your own for a flywheel, clutch etc. You will just have to figure that out, or find it in a swap article or elsewhere. Some of that will depend on what trans you go with. As always, an automatic is a much easier item to deal with. It will require a controller as well, so decide on a trans and see if you can get a controller that works both engine and trans.
This is an expensive and complicated swap. Your 6 cylinder truck, what year is it? Is it in excellent overall condition? Brake and steering issues are only going to get worse with more power.
Old 10-01-2016, 09:22 PM
hunter ashwood
it is in pretty good shape iv been taken care of her and its a 1991
Midnite1987
10-30-2017 08:13 AM
Nick_P
16
07-03-2017 03:47 PM
94flaresideon20s
04-08-2013 10:14 PM
crack
09-09-2007 10:45 AM
falcon5spd
12-24-2006 11:35 AM
Quick Reply: inline 6 to a coyote 5.0
