2000 Ranger 2.5 L4 battery light
Approx 6 months ago I had this problem and was able to wiggle wires re-seat fuses etc... and the problem was gone. Now it is back but wiggling wires re-seating fuses doesn't resolve the issue. This time it appears to be the voltage regulator due to headlights dim and get bright battery light comes and goes right along with the headlights dimming etc... Is the voltage regulator portion of the alternator separate from the alternator? Can I replace just the voltage regulator?
Before throwing parts at this problem, consider running this puppy by your favorite auto parts store & ask for their electrical system test guru to perform a no cost, in vehicle, under load electrical system check up, with their electrical system tester, get a print out & report back with the test results.
How many miles on this alternator??? If many miles, with the charging coming & going, could be worn slip ring brushes.
Since the alternator was recently replaced & you've been having problems with it for some time & a previous wire & fuse wiggle test woke things up for a while, have a close look at, or better yet use your multi-meter to measure the B+ & B- connections between the engine & battery for under load voltage drop.
If your going to install it, have them bench test the replacement before you leave the shop with it.
Was this one a New, or Reman alternator? If new, make sure the replacement is a new one too & let us know how it goes.
garymc
1983 - 2012 Ranger & B-Series
02-20-2003 11:23 AM
