What to look for when my headliner is down
A couple months ago I found a thread that had some pictures of a man's excursion ceiling with the liner down. there were some rust spots and he told about something he sprayed on them (I dont think he cut them out or patched them)
but I cant find that thread. Can anyone answer what that might have been he put on them or point me to that thread? I cant find it now and I am about to have a dvd player installed and would like to have the celing deadened while I am at it and to try to take care of any possible rust spots while the liner is down.
I assume it would cost exponentially more to have the liner taken down past where the player goes (right?) so I probably wont have the ceiling behind the player done. Would it be worth it to have the ceiling to the player deadened? I would think any little bit would help. and with any left over deadener I would do the doors anyway
It's all or nothing. If your going to drop the headliner do some insulation(heat wave pro or styrofoam depending on your budget) and some sound deadener. Yes, it is a two person job. There is nothing between the headliner and the metal roof that's why the X sucks in the summer. I did both of the above and tinted the front window- huge for Florida heat. Can't they install the DVD without dropping the headliner?
how long to replace the stock dvd player?
thanks for the response.
this is what I have ordered
https://www.amazon.com/gp/product/B0...iglink20368-20
and
I need to order more unless you advise me against using this stuff.
I shouldve put this in the original post but the installer told me the entire liner had to come down, it was a 6 hour job at least (at 60$ and hour) and he would have to make a bracket for the dvd player.
Is this correct do you know? I didnt ask if he had done an excursion before.
which foam did you use?
https://www.amazon.com/s/ref=nb_sb_n...expanding+foam
I like closed cell foam.... this stuff is 2lb density so it has some structural strength but it ain't cheap.
Fiberglass Evercoat Sealant Foam 12-Ounce Spray Urethane
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I wouldn't think you would have to pull the headliner to in stall a dvd. Should beable to get it down enough to do what needs to be done by a guy who knows what he's doing. Now with that said I tend to over do things and would probably pull it and sound deaden the roof while doing it. But that's me.
And I read elsewhere on this forum (again, I cant find it now) that the headliner did NOT need pulled down for the dvd replacement. I wish I could find someone that had replaced the dvd player on an ex and could do mine without taking down the headliner (I could spend a couple hundred on diesel getting there and still come out ahead). and get my speakers put in my doors and the subwoofer put in while I'm at it.
may some foam along the brackets with the above deadener and insulate between the?
