460 smoking
Old 09-25-2016, 07:08 PM
william16339's Avatar
william16339
william16339 is offline
460 smoking
I need some help here. I'm about to junk this 460 and get a crate motor.... So I go ahead and did the top end. New lifters. Pushrods. Cam. I think bottom end is fine because it holds 75 psi cold and 40 warm at idle. Of oil pressure. When you rev the truck it doesn't smoke, only after the rev comes back down to idle. It smoke a tad of blue.
When I lean out the Idle mixture screws it does it less. Is it valve guide seals or gas? I don't smell oil. And it doesn't burn it.......
Old 09-25-2016, 11:17 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,599 Likes on 1,304 Posts
Did you replace the valve stem seals?
Old 09-26-2016, 08:16 PM
william16339
no i did not
Old 09-26-2016, 11:46 PM
85e150's Avatar
85e150
It can be done with the heads on, but you will probably need to find a shop to do it as you need a special tool to hold the valve and pull the spring etc, along with compressed air in the cylinder to keep the valves seated during all this.
reifwj
23
05-30-2008 03:07 PM
magwheels
11-14-2006 06:27 PM
tys78
10-04-2004 12:13 PM
roscoe69
03-04-2004 10:19 PM
zimman20
11-14-2002 01:24 PM
Quick Reply: 460 smoking
