Missed Connections
Old 09-25-2016, 12:37 AM
Atlas45's Avatar
Atlas45
Atlas45 is offline
Missed Connections
Can y'all help me figure out where these vacuum amd electrical connections go? It's a 1983 F100. Thank you.
Looks to be some kind of solenoid.
I believe thhe green vacuum line is connected to the EGR valve.
A wire that seems to be loose and comes from an engine accessory below the smog pump.
Old 09-29-2016, 09:49 AM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
That Carb Solenoid looks like either a Fast Idle Solenoid or Anti-Diesel Solenoid. I believe there should be power to it in Ignition Run position. Time to check Schematics and Carb Diagrams... which I don't have...
Old 09-29-2016, 09:58 AM
Harte3's Avatar
Harte3
Harte3 is offline
Do yourself a favor and replace those hard plastic vacuum lines with rubber lines. With the age of these vehicles those plastic lines crack, split, break and are a common cause of vacuum leaks.
Old 09-29-2016, 01:29 PM
Atlas45's Avatar
Atlas45
Atlas45 is offline
We are probably going to be replacing them with rubber lines. There's not a lot of it and it's easy to replace. Thanks for the tip. Any ideas on what the last photo is?
Old 09-29-2016, 09:30 PM
The Frenchtown Flyer's Avatar
The Frenchtown Flyer is offline
That looks like the connection to the electric choke cap. Put a voltmeter on it first with 'key on' and second while the engine is running.
Old 10-01-2016, 11:07 PM
Atlas45's Avatar
Atlas45
Atlas45 is offline
What should the reading with the "key on/accessory" be?
Old 10-04-2016, 09:52 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
From the factory, the choke feed wire was attached to the "S" stator of the alternator. There should be zero voltage when the engine is not running.
Old 10-04-2016, 01:35 PM
Atlas45's Avatar
Atlas45
Atlas45 is offline
Thank you so much. The truck would not want to idle. In the past, my grandfather held the choke open with a steel clip and fed it gas until it warmed up.
James Wagoner
18
05-19-2018 12:11 AM
Givens54
02-18-2016 07:35 PM
Wolfmancc
1978 - 1996 Big Bronco
10-06-2015 01:22 PM
Jtay561
13
02-12-2015 05:01 PM
jgavac
12-25-2011 03:23 PM
Quick Reply: Missed Connections
