1987 Ford F-250
Old 09-20-2016, 10:30 PM
cosmo10's Avatar
cosmo10
cosmo10 is offline
1987 Ford F-250
my Ford F-250. has a choke dash pot and this dash pot has a wire that comes off the bottom of said dash pot and were does it GO. thank you
Old 09-21-2016, 09:25 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,409 Likes on 2,100 Posts
Moved from 6.0L diesel thread, guys should be able to help you here better but I will give it a shot.
You have 3 types of choke mechanics, one is vacuum, other is mechanical using a spring that heats to pull off the choke as the engine warms and last is 12 volt.
The spade terminal is supplied with +12V from the alternator’s stator terminal. Whenever the engine is running, the ceramic heater warms the bimetallic thermostat to open the choke.
Old 09-21-2016, 12:06 PM
cosmo10's Avatar
cosmo10
cosmo10 is offline
1987 F-250 chock to Altenater.
so what your saying is that there is a female wire combing
from the Altenater that plugs in to the choke dash pot correct me if I'm wrong
Old 09-21-2016, 05:28 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
There is a white/black wire coming from the alternator stator that provides around 7V to your choke coil.
Only aftermarket carbs take 12V, and they have + & -- spade terminals not just a single bullet like the Motorcraft choke cap.
Old 09-21-2016, 10:15 PM
Maxium4x4's Avatar
Maxium4x4
Thanks for the voltage correction, I never worked on one of these kind of an old GM gasser guy from the days gone by.
Old 09-22-2016, 03:37 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You offer a fine description of how the choke system works.
Yes the wire splices into the alternator harness
Power on the stator wire is 1/2 wave, whatever the charging current is.
My 1987 carbureted F 250 charges at 14.35V, so....7.17 or so?
dgoodsy
03-20-2019 09:05 AM
Rick_Fury
12-04-2011 08:49 PM
dnachristen
Bronco II
06-18-2011 01:55 AM
hoxiii
19
03-15-2007 01:00 PM
paul739
Electrical Systems/Wiring
05-22-2003 07:30 PM
Quick Reply: 1987 Ford F-250
