p 1639....VID block corrupt
Yep I have this code on my truck...2008 f250 6.4 with H&S xrt pro tuner. The other day I went to change power levels in order to pull trailer. Long story short...plugged in tuner....changed level and it froze and check engine light, abs light and battery light came on. Now rumor has it the only way to fix this is to have Ford flash truck with the as built data and re tune.....however I remember hearing when H&S was still around they had a fix for this through their tech support. Has anyone delt with this...other the going to Ford?
So I'm guessing no ones had this issue? lol Just want to update....fix is definitely to have pcm re flashed with as built data from Ford and then re load your tuner. Had mine done this am, took about 40 mins or so.
Also figured out what caused it......My Kenwood stereo ties into my obd2 block so it can show gauges and read codes etc, however when tuner is plugged in to change power levels...the tuner and stereo have a small fight I guess and well it wipes the vin # and other things from the pcm. Not sure if other tuners will have this issue...but my H&S tuner did. Just a heads up for anyone else set up like this.
I have been experiencing
Not so sure I would do that. The route I went was to just unhook my stereo from the obd2 wiring. The gauges on the stereo were cool and all, so was the ability to read codes....but I never really used them. If you want to keep your stereo wired into the obd2, what I would do is splice in some connectors or a plug into the 2 wires from the stereo that tie into the obd2 of the truck. Leave these connectors or plug someplace easily accessible, and when you want to change power levels with your tuner simply unplug the stereo to obd2 connection. When finished changing power levels connect the stereo once again.
