351m dipstick tube leak
Old 09-19-2016, 09:17 PM
daltonjamesadams's Avatar
daltonjamesadams
daltonjamesadams is offline
Is there a o ring around it? Leaking, but not moving around,of course its mounted behind alternator bolt.
Old 09-20-2016, 06:44 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
I think you are asking if there's an o-ring where the tube goes into the block. I don't know as all the ones I've seen as well as those in the parts catalog I have go into the pan.
Old 09-20-2016, 10:50 AM
Filthy Beast's Avatar
Filthy Beast
Filthy Beast is offline
You have a front sump, 2 wheel drive, correct?
The dipstick tube has a "lip" where the tube sets in the block...I believe it's slightly tapered below that where it fits into the block. It's a press fit and probably has an "O" ring there. Going from memory here and it's not as good as it once was....sounds like a Country song?....."I'm not good as I once was, but as good once as I ever was." Hahaha
Old 09-20-2016, 07:11 PM
daltonjamesadams
Thanks youall, i will try to check it out better. Leaking around it and dripping down on crossmember.
Old 09-24-2016, 10:03 AM
POPAJON's Avatar
POPAJON
POPAJON is offline
I have never seen an O-ring on one of the tubes. If it is leaking it has probably been worn down or crushed. Put some RTV around it under the crimp. That should stop your leak .
Old 10-09-2016, 01:04 PM
daltonjamesadams
Kinda embarrassed, i think it was the valve cover leaking and running down the front of the block.
Old 10-09-2016, 01:11 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
That will do it. And, don't worry - we've all either "been there" or haven't wrenched enough.
Old 10-09-2016, 05:23 PM
mark a.'s Avatar
mark a.
mark a. is offline
It isn't a "O" ring. It is more like a rubber sleeve. You should be able to get one through Ford. The 460 rear sump used the same thing.
Old 10-29-2016, 07:09 AM
daltonjamesadams
Thanks to everybody
Old 12-10-2016, 06:55 AM
daltonjamesadams
Well, its at it again. What is a common a leak issue in this area?
Old 12-17-2016, 01:10 PM
beartracks's Avatar
beartracks
beartracks is offline
Intake manifold maybe. I'd clean it off real good and then watch it closely to see where it's coming from. Make sure your PCV system is functioning. I've been known to restrict the intake air to the PCV in order to create a slight vacuum in the crankcase. Tends to suck in oil leaks and help idle quality.
Old 12-18-2016, 06:25 AM
daltonjamesadams
Thanks. I have replaced the pcv valve and it seems to be working fine, i will try to check the manifold.
billcollector
04-17-2021 08:58 PM
JD_F250
10-27-2014 06:33 PM
nlemerise
05-29-2012 11:53 AM
PsD007.3
11-13-2010 03:06 PM
Mikonoclast
05-13-2002 08:18 PM
Quick Reply: 351m dipstick tube leak
