What were they thinking?
Old 09-17-2016, 05:44 AM
Order and Chaos's Avatar
Order and Chaos
Order and Chaos is offline
This is dedicated to everyone wanting to comment on things they have found on their trucks that have left you flabbergasted and confused as to what the thought process was of the previous owners when you decided to repair, replace, or update something on your truck.
I started on the power steering install for my 65 F-100. With the exception of the pressure and return hoses, I have everything I need. The original column came out easily, and I dropped it off at the steering column shop nearby to have it shortened and fresh bearings installed. With the front end on jackstands I crawled underneath and intended to disconnect the right tie rod from the pitman arm. There's a substantial build up of road grime on everything under there and can't see the ends of the cotter pin, so I grab the soda blaster and do some seriously needed cleanup on the suspension and steering components.
With everything clean and armed with my needle nose pliers I go to pull the cotter pin, only problem is, I still can't see it. Now I'm confused. Giving it a closer look is when I realize someone used a plain flat nut instead of the correct castle nut, and to replace the cotter pin, they did an excellent job of WELDING the top of the nut to the exposed thread of the shaft. Not just a tack weld in a spot or two, they welded it in a full circle.
I guess my new die grinder gets to be tested on my next day off.
Old 09-17-2016, 07:53 AM
A Seabee's Avatar
A Seabee
A Seabee is offline
They didn't want it to fall off!
Old 09-17-2016, 08:37 AM
john jamieson's Avatar
john jamieson
john jamieson is offline
"I'll never have to take it off."
Old 09-17-2016, 01:34 PM
Order and Chaos
I guess I should be glad they didn't buy tires with a lifetime warranty, heheh...
Old 09-19-2016, 10:01 AM
Bostonbob's Avatar
Bostonbob
Bostonbob is offline
Yep it's fixed
Old 09-23-2016, 01:01 PM
Order and Chaos
Well, with about 20 minutes worth of careful grinding the welding was removed. As I ground away I figured out what they did. Someone had used a 3/4 - 1 ton style lug nut backwards, with the flat side towards the pitman arm and the conical side up. It took less time to remove the manual steering gearbox than it did to undo the tie rod/pitman arm connection.
progress...
Cracker289
29
08-04-2015 07:40 AM
Yankeeblade
1999 to 2016 Super Duty
01-21-2014 03:57 PM
iwanaflattie
01-26-2011 09:26 PM
statesboro_blues
06-20-2003 08:48 AM
Cory Elliott
13
06-30-2002 06:06 PM
Quick Reply: What were they thinking?
