1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Batteries keep running down
Old 09-11-2016, 06:41 PM
HillbillyJoe's Avatar
HillbillyJoe
HillbillyJoe is offline
I have a 2006 f350 superduty 6.0l diesel and if one of the batteries are bad will it drain the good battery...had them tested and one tested good but I keep having to charge them both
Old 09-11-2016, 07:44 PM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
Yes. If you run a bad battery in parallel with a good one, the bad one will kill the good one every time. Replace the bad one, before you end up having to replace both at the same time.
Old 09-11-2016, 07:49 PM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
You should replace both batteries at the same time even if one checks good. The only time you only replace one would be were one battery is under 6 months to one year old.
mottrocks
08-17-2010 01:44 PM
Delawhere?
01-05-2010 08:58 AM
r-man
02-24-2009 11:36 AM
live2hunt
03-26-2006 08:30 PM
JRB
07-13-2005 09:06 PM
Quick Reply: Batteries keep running down
