Washable cotton type filter with Banks turbo...
I am working on tying up loose ends with the 6.9 project. As many of you probably know, I am installing a Banks Sidewinder on this engine along with a ton of other things. The air filter system that comes with the turbo has a K&N style filter. It's my understanding that this is not a desirable way to go because this type of filter on a diesel, they still let smaller dust and dirt particles in. I was thinking about it this week, I wonder if adding a pre filter sock would help. I'm running one on my Bronco, it works really well. Or am I still better off going to a paper type filter, any thoughts? If anyone else a home brewed setup, I am open to that too; pictures?
As far as I can tell, everyone is correct:
1. The K&N style filter can let in dirt
2. Dirt is not good for a diesel
3. Banks designed their system with a K&N filter, so they obviously consider it good enough.
At this point, I am running a K&N knockoff filter, because at $20 per it's cheaper than the cheapest paper filter I could find with a 4" round connection.
I haven't noticed any dust issues or dust making it's way in... but I also learned the secret of these filters: They need to be soaked in oil(the K&N "recharger" system) to trap those fine particles.
K&N says not to over-oil the filter to prevent issues with MAF sensors... who cares? Oil the snot out of it and clean it once in a while. Any oil that gets sucked into the system should be burned just fine.
The only other economical option I've looked at is seeing about adapting a Ridgid vacuum cleaner paper filter - at $12 for the single layer paper filters, they are pretty good price wise. You'd just need a 6" or so to 4" adapter, and fabricate something to hold it in place - the vacuums have a plastic plug that sticks out the end of the filter and holds it in place.
You can spend some time looking @ Donaldson air filters, and I bet you'll find what your looking for. https://www.donaldson.com/en/engine/.../cleaners.html
They may not be washable though...
I did a little shopping around and located a pre filter sock for my air filter. I have one of those coming, we'll see what happens.
Received 3,114 Likes
on
the 6637 i took out of the 02 and put into the 88 had 56,000 miles on it when i swapped it to the 88. i use a riff raff filter cover on it. i actually have 3 of the covers, one on each filter and one spare. every 6 months i remove the one on the 02 and put the clean one on, then wash the dirty one and hang it to dry for future use. after 7 years and 56k miles, the filter still looked new and did not have any dirt/dust in it when i tried to blow it out.
the covers on the other hand look like hell after 6 months.
on
My 6637 should arrive today. Been playing around with the positioning. I'm not as handy as most of you guys so I lack that confidence when building/adding something new (like welding 4" pipes or even using pvc pipes). When it gets here, if there is some balance in the universe, It will fit directly on to the intake. If its an inch too but (like the measuring tape told me), I will need to tunel it somehow. Here is my "cheat" to avoid adding anything except a 4" x 3 or 4" coupler.
What do you guys think of this positioning. Directly above the power steering.
Here im just using the old filter to give an idea of how it will be
Just using the old filter to show the positioning
I know the 6637 is 1" longer and much wider.
on
