2014+ Transit 2014+ full size Ford Transit Van, Wagon, Cutaway and Chassis-Cab
Aftermarket remote start? 2015 transit 250
Old 09-02-2016, 10:51 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
Has anyone installed an aftermarket remote start on a 2016 transit 250? Easy plug and play? Anyone try fortin evo all brand?. Having trouble finding one.
Old 09-24-2016, 10:29 AM
kbsupercrew
Well I installed fortins evo all stand alone system, 150 dollars compared to fords oem 400 dollar system that includes a flash required.
Note: It doesnt have a transponder in the key so the programming was a little different, can bus programming only and the remote starter couldnt read the factory key alarm fob so a aftermarket fob was needed, crimestopper revo1, which was an additional 35 dollars.
All in all it does what i need it to do which is start the van in the mornings during the cold months.
Old 10-03-2016, 07:13 AM
asdrew's Avatar
asdrew
asdrew is offline
I bought a simple Viper 4115V remote start for my 2015 T350 wagon from an eBay seller, but have not had an opportunity to dive into the installation. I don't have an alarm system nor do I desire tying into the door locks, so it should be a straightforward tap into the ignition circuit.
The biggest task seems to be locating and connecting to the right wires, and Viper is extremely secretive on providing information to anyone but authorized installers (probably due to liability issues). I've been hacking into vehicle wiring since I installed my first 8-track player and I got good information from the12volt.com, so I'll get it figured out eventually.
Can you provide any insight into where you connected wiring?
Old 10-03-2016, 10:33 PM
kbsupercrew
Old 10-03-2016, 10:45 PM
kbsupercrew
If your barrel looks like this you dont have a transponder, if you look , there is no plug connection at key end.
Old 10-03-2016, 10:53 PM
kbsupercrew
Also since there is no rx,tx connection ( transponder), you have to find a ground for your remote start, I used the frame of the steering column( the blue wire on left side of picture with the blue t-connector to the black wire which is attached to frame of the column for my alarm neg. . hope this helps
Old 10-04-2016, 11:19 AM
asdrew's Avatar
asdrew
asdrew is offline
Thanks so much, that gives me a big leg up!
cemenacho
05-08-2013 06:00 PM
george6488
2009 - 2014 F150
07-07-2010 08:05 AM
gradynh
2009 - 2014 F150
08-21-2009 04:31 PM
rschertler
1997 - 2003 F150
01-25-2009 01:14 PM
msu_fan
2004 - 2008 F150
06-09-2004 03:40 PM
Quick Reply: Aftermarket remote start? 2015 transit 250
