2005 F350 Heavy Duty 6.0L Break fluid leak
i have a 2005 F-350 XL truck that has 68,XXX miles i recently changed the rear brake pads and about a week later the rear passenger side is leaking brake fluid.The fluid is slowly dripping from the bottom caliper bolt but i am not sure if there are seals in this area. the driver side is fine and the fluid is only leaking from the bottom caliper bolt not the top.
