Sponsored by: Real Truck
brake fluid leak
Old Oct 26, 2005 | 11:06 AM
05ford's Avatar
05ford
brake fluid leak
have a 2005 f250 superduty. notice that there is some brake fluid around and on top of the brake fluid reservoir. i havent put or changed the brake fluid. nor am i running low but find it odd to have some on the outside. cant seem to see where its coming from.
any one else have this problem or have any suggestions.
oh and by the way the cap to the reservoir seems to be in good condition.
thanks
Old Oct 27, 2005 | 01:54 AM
texans's Avatar
texans
I dont think this is anything to worry about. Somtimes they just get condinsation built up around that area that cause dirt to stick to the MC. That is what I have found. Im sure someone can explane it better than me though. As long as the MC is full then I wouldnt worry about it. GL
Old Oct 27, 2005 | 01:43 PM
05ford's Avatar
05ford
thank you for your help. yeah it remains full. ill just keep an eye on it for a little while more. hopefully that its just what you said it is.
thanks again
Old Oct 28, 2005 | 01:13 AM
texans's Avatar
texans
your welcome just keep an eye on it
Old Oct 28, 2005 | 01:33 AM
ford390gashog's Avatar
ford390gashog
yeah just watch it. if it gets worse have it fixed
Old Oct 29, 2005 | 10:00 AM
95CobraR's Avatar
95CobraR
Maybe they just over-filled it a bit?
When it gets hot due to heavy braking, the fluid will expand and could overflow a bit.
I'd take a little out of the reservoir. It will get on the paint and take it off.
Old Oct 30, 2005 | 08:30 PM
05ford's Avatar
05ford
fluid is at the max line. still has some along the sides but still full and nothing wrong with the brakes so its all good.
will still keep an eye on it.
thanks guys
