Trailer has running lights but no turn signal or brake lights
2013 F250 XL with factory towing package.
My camper and boat trailer do not have turning signal or brake lights when plugged into the round seven pin trailer connector. I have tried both the connector in the bed and under the bumper. I've also connected the trailers to other trucks and the lights work fine so I know the problem is in my truck.
Thoughts?
Thoughts?
Have you taken a voltmeter or test light and checked for at each plug to see if you get the brake or turn signal voltage or light the test lamp? You need to do some investigation. Got to parts house and buy a test lamp or go to Harbor Freight and get a cheap voltmeter.
No one can guess you fix without more input at to suggest a fix.
I just saw that the op started this thread months ago, so he probably already resolved this. But, the way I understand his post "I've also connected the trailers to other trucks and the lights work fine". He did not say other trailers worked with his truck, but rather his trailers worked with other trucks.
billy layton
1999 to 2016 Super Duty
10-10-2017 01:58 PM
Loveland
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-20-2012 05:59 PM
rangerxlt02
10-01-2005 11:49 AM
