99 7.3 camshaft wear replace ?
My vote is for a new one. Time has passed and things have changed a little since I delved that deep into the bowls of a diesel but way back when I did I was told that the cam is only hardened on the outer edge (case hardened) and that it didn't take much to get past that surface. That one lobe is pretty torn up. Additionally, with the amount of steel that you'll have to grind off of it, I don't think you can do anything like you can with a bored out cylinder (larger rings or piston) and you will change its dimensions.
Just for comparison, I'll share a photo of the cam still an OBS 7.3L:
No flat spots, rough patches, grooves, or pitting. In your picture... I see the glare disappear on the worn part of the cam. This means the surface is roughened, and it will act like sandpaper on the lifter. I'll bet those lifters are done as well.
The lifter are actually all in great shape. They don't match the cam condition but I just don't feel good about putting this cam back in. Does any one know where I can find another one ? Stock replacment. I'm having a hard time finding one new. I have another engine I can rob it out of but would rather get new.
CAMSHAFT for 1999 Ford F-250 Super Duty|F81Z-6250-AA
And any International dealer should have it too.
BTW you might consider new lifters too, they're something that wears into a match with the lobes that they ride on and a new cam might wear differently on them. Others here can probably tell you if I'm off base on this.
Ya I already had it quoted to have them replaced I just didn't plan on the cam being bad so there will absolutley be new lifters going in. I would like to find out how this happened tho. It's in a manual trans truck so I'm thinking it is from to much rpm over the years. It has 239000 miles and the bearings, crank, and pistons look pretty good it's just the cam. The reason for rebuild is low compression, all of the cylinders were 280 - 330psi. Customer just wanted to have the engine 100% again it did run pretty good with the compression it has didn't smoke to bad ether. But I did include new HD lifters from dynamic diesel in the original quote. Thanks walleye hunter, I will check it out. I just searched Google to find one. I'm going to ask my local machine shop to get a price as well, try to keep the money local if possible
Jst curious. Any history on oil change interval? Oil in my truck has ben changed at ~3k intervals since new and is still "clean" - on the dip stick at least. Nothing fancy, "old formula" DELO 400 15W-40. Just because the OA says all of the additives are good to go does not mea that it is not full of soot - read "polishing compound".
