1948 Ford F6 Brake Line question
I purchased a replacement kit for brake lines.
It is 3/16 inch metal brake line replacement kit, 3/16" with 3/8" fittings. But the truck currently has larger diameter brake lines and fittings.
What should be used? My F6 doesn't have a booster. One line running to the rear, two lines running to the front off the master cylinder (which I also have purchase a new one).
I'm doing this because my master cylinder is leaking out of the front.
Thanx.
Thanx.
Pic of 1948/52 F5 (T); F5 COE (W) & F6 (TH); F6 COE (WH) brake system from the 1948/56 Ford Truck Parts Catalog, available on a C/D from hipoparts.com
This is the catalog that Ross mentioned, but it does not include body parts for 1948/52. You would need a 1944/52 Ford Passenger Car & Truck Body Parts Catalog, that is not available on a C/D
It's reprinted (bound paper) by faxonautolit.com .. but it's half the size of the original and 75 bucks. Originals can be very hard to find.
76CamperSpecial
05-29-2008 07:59 AM
