Tires
Tires
I will be needing new tires shortly and I think I have it narrowed down....but would like some opinions on them. Probably should be posting in the tire section but I really want super duty comments. Going on my 09 which is not a daily driver. And I want a little more aggressive tire-not a mud type or a street tire, but somewhere in between. I live in Michigan so we actually have 4 seasons, sometimes all in one day. Size will be LT285-70-17 unless I can find a set of factory aluminum 18".
1)Cooper S/T Maxx
2)Cooper Discoverer S/T
3)BFG AT
4)General Grabber AT
Pros/cons of each....Thank you
1)Cooper S/T Maxx
3)BFG AT
My GrabberAT2 destroyed my rocker panels with flying rocks retained from my driveway. I have done a lot of tire searching and shopping. The Maxx are #1 in my area, it is my top tire choice if they are available in the needed size. The Maxx also have a great selection in the 18" size if you went that route.
These are similar and I believe they are made by Cooper. I guess I'll check on prices
CooperMastercraft - Courser CXT
i love my BFG A/T KO2 so far (about 3k miles on them i believe, which reminds me, i need to rotate them lol)
actually just cleaned them up today with some degreaser, i love when the white letters are nice and clean and pop against the black sidewall like this.
original pic first then a filter applied on the second. the pic above of the tires is unedited though.
Superduty tires
Well I always loved the BFG T/A
But on both of my superdutys they just don't cut it . They wear out fast and hydro plain above 65 mpg just on a wet road . I switched over too general AT 2 and loved em on my 04 Superduty crew cab 4 door has job .
Sold a ton of them at my shop . Well my 08 Superduty 6.4 ate the suckers up.
I called my tire supplyer and he said oh run the toyo's. I said I don't want jap tires on my truck . Come too find out they are made in USA.
I went with the toyo open country AT2 extreme and love em . Truck no longer wonders road noise is minimal . They also offer a open country RT rough terrain it's in between the AT2 and the mud terrain . We just installed 2 sets on 2 different superdutys and the guys love em . We are out here in Arizona so the real aggressive tires make more heat on the road which is already extream even 4 hours after the sun goes down . I would absolutely recommend the toyo open country AT2 extream . The regur AT is not as aggressive so keep that in mind .
i haven't noticed any hydro plain issues yet, although i rarely drive over 50-60, maybe 70max on the interstate because it starts to death wobble lol. and especially when it's raining i probably dont go over 50 in this truck.
Death wobble could be either bad front shocks or the track bar is worn out .
Usually it's one of those . Not ball joints or toe rrod ends .
That's usually what people think when they come into the shop and tell us what they think .
If you do happen to replace your track bar get the adjustable one . You can pick one up on e bay for around a $100.00
BFG's is the only one I have experience with. Had a couple sets of them. I live in Northern Indiana and grew up in Michigan so have experience with your weather concerns. They are a pretty good all around tire. I would get around 45,000 miles or so out of a set. I would say ice and mud performance would be the worst area I found with them. I really found that out when I started snow plowing. If you need just an all around tire I think you will be happy with them. Make sure you get the load range E's. BFG likes to try to sell you D's for our trucks. I actually have switched to Goodyear Duratracs for the past two sets, and will not turn back. Love these tires and they also carry the severe weather rating.
also after the shackle lift, the steering wheel was crooked. we tried adjusting it back as close as possible but it's still a hair to the right. i'd like to eventually fix that also, would the adjustable track bar help with that or is that the "drag link" i'm thinking about?
sorry OP for going off topic. Joey if you want, PM me so we don't hijack this thread haha.
The track bar works like a pendulum . As you lift the truck the bar needs to be made longer and vice Versa as the weight of the engine makes the truck slump down in front over time it needs to be made shorter . This also make it possable for a way better alignment and frees up the front end . Gets rid of that twitchy feeling .
