Excursion 2011 exterior conversion hwybee22 project build
This is where the bumper mount on the frame was cut off and welded back.
The 2011+ F250 fenders bolts near the bottom of the pillars and we welded a block of metal and threaded it, so that the fenders are extremely sturdy.
This is a small clip that the McNasty kit calls for you to use a rivet to mount it. We went a step further.
Thanks. The hardest part was collecting the parts, as I started at the beginning of this year. Then it was the speed bumps, when we had to get creative to make it secure. I took it for a road test yesterday and everything stayed on the Ex. I purchased a kit from McNasty Customz which made it easier to put together, but I realized that it not 100% bolt on and alittle more cutting/welding was needed.
I've left to work out of town for a couple of weeks, but my brother is still working on it. The only things I know that he needs to complete is the wiper assembly/cowl and I have a huge vibration, which I believe comes from us removing the complete axle and suspension. Then I have a wedding in the middle of September that we're using it for a trip to the outer banks and then it going under the knife again to add the 2011 rear quarters. I'll see if he'll take pictures for me, but he may not want to until he's totally finished with the front.
Just had mine down in Nags Head, then Hatteras this past week
Since I'm still out of town, my Ex has been put on the back burner with all the work my brother has. Today I was told he molded and trimmed my original inner wheel well on the passenger side to match up with the +11 fenders. I will come home next week and would love to finish it up. Installing the new cowl will need some creativity because I want it to look as factory as I can. More pics to follow
#29
Today my brother decided to tackle installing the cowl, which is 2 piece. He found out that alot of trimming was needed so the cowl would sit flush. He also slits near the existing holes where the 05 cowl snapped in. Since the +11 cowl is much wider, he's going to weld brackets for the front clips to snap in for a more factory look than putting screws thur the cowl.
He painted the bottom of the cowl because he needed to see where the cowl was hitting
He cut out a hole, so the it would be flush.
Also had to cut and trim by the antenna to make it sit correctly.
#30
