Weight in the bed for snow
weight further back puts the load on the rear axle... Putting 300# of weight 2 ft behind the axle will NOT decrease steering ability or make it less stable.. The front tires are maybe 12 ft further to the front so the "LIFT" on the front end will be 25 POUNDS or NOTHING.
The leverage effect on the front axle is what he's talking about. You could calculate it using the rear wheels as the fulcrum etc etc.
What my concern is, and it's not a big concern for me as I no longer live in snow country, is the "Moment of inertia":
https://en.wikipedia.org/wiki/Moment_of_inertia
Now y'all can read through all that stuff and do the calculations. Or, if you have lots of extra weight behind the axle and not very prudent in your driving, your "moment of inertia" would be when you discover yourself sideways or backwards at an inopportune time and place.
Spin a barbell with the weights in the center or at the extreme ends. See how that works.
In reality, most people will never have an issue. But the consequences being what they are, I would err on the side of having the weight no further back on over the top of the rear axle.
For those with insomnia:
http://www.car-engineer.com/vehicle-...culation-tool/
In front or over the top, that's what I'm saying.
The major issue is to make sure it's secure.
Look it's a popular idea--weight in the winter, haul water in the summer:
Shur Trax All Weather Traction Control Aid
not saying it couldn't happen, just doubt it could
in all honesty I quit using weight in my trucks years ago, just slow down or don't go at all if it's that bad out.
#1 thing is make sure you've got good tires!
Tom Mix, a huge movie Western actor way back in the day, was killed by a projectile: (Wiki)
"About eighteen miles south of Florence, Arizona, Mix came upon construction barriers at a bridge washed away by a flash flood. Unable to stop in time, his car swerved twice, then overturned in a gully. A large aluminum suitcase containing money, traveler's checks, and jewels, situated on the package shelf behind his head, hurled forward and struck him, breaking his neck. He was 60 years old."
Maybe the problem is what is meant by "projectile", it's what happens in a collision is the problem. Toolboxes, coolers, spare tires, gas cans, blocks of wood, chains etc. **** goes flying. Collisions that were otherwise survivable have been deadly because of objects flying around. A sandbag could definitely **** your day up.
Tom mix, 75 years ago, 1940
Not in a truck
stydel311
62
12-12-2013 04:13 AM
Dieseldan7.3
01-07-2005 11:06 AM
