motor mounts 1989 E350
Old 07-27-2016, 02:11 PM
maltondhc's Avatar
maltondhc
maltondhc is offline
Motor mounts on my 1989 e350 Rv with 460 engine getting tired, engine shifts a bit. Question, how is the best way to lift the engine the few inches needed to change them? Manual I looked at suggested lifting on the oil pan, but I suspect that might be more appropriate for small blocks rather than this heavy beast big block. Anyone been down this road?
Thanks
Jeff
Old 07-27-2016, 06:01 PM
Tom's Avatar
Tom
Tom is offline
Yup, you can still lift it by the oil pan. I'd put a block of wood between the jack and the pan to avoid damage, but it should be fine.
Big block? Small block? Isn't that GM terminology?
Old 07-27-2016, 06:13 PM
vettex2's Avatar
vettex2
vettex2 is offline
as above, wood block on a jack under the pan
Old 07-27-2016, 09:39 PM
maltondhc's Avatar
maltondhc
Tom:
You are right, have more experience with Gm,s than Fords ( same GM Dustbuster van in driveway for over 20 years). Thanks for the replies, while oil pan certainly looks robust, I understand weight of this engine, dressed, is approaching 1000 pounds. Was considering using the harmonic damper to raise engine. If something went sideways, balancer a lot easier to repair than oil pan, but will take a look. Thanks for the replies.
Jeff
Old 07-27-2016, 11:13 PM
vettex2's Avatar
vettex2
vettex2 is offline
Do not use the dampener !
I watched a guy snap the crank.
You might see how "easy" that is to repair.
Old 07-28-2016, 09:18 PM
maltondhc's Avatar
maltondhc
vettex2:
Thanks for the heads up, makes sense..oil pan it is I guess
rudypoochris
01-15-2007 04:30 PM
sharkdance
03-25-2005 09:36 PM
77fordguy
Garage & Workshop
15
10-22-2004 08:04 AM
dbarracuda
09-21-2002 05:24 AM
cjben
08-03-2002 03:58 PM
Quick Reply: motor mounts 1989 E350
