1966 question?
Old 07-30-2016, 07:43 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Originally Posted by 2005REDFX4
Not looking for 110 but 60-65 would be nice. Mostly be used for hauling firewood, getting back in to the hunt club, towing whatever I hook up to, etc....
It'll do it fine - it will just use a little gas.
Old 04-18-2017, 08:07 PM
Steve Schmidt's Avatar
Steve Schmidt
Steve Schmidt is offline
Master cylinder
I have a 1966 mercury 500 2 ton.
looking for direction on where to get a rebuild kit for the master cylinder. Been looking online a lot, and can't seem to find anything.
It's a midland 300246 part number. If that means anything.
Thx.
Steve
All 500 and larger series trucks came with DRW's (dual rear wheels).
1953 and later F350's were also available with DRW's, but there were no F350 pickups with DRW's until 1980.
F250's were not available with DRW's until 1985. F100/150's were never offered with DRW's.
Prior to 1980, DRW F350's were sold as a Cab & Chassis (no "back of cab equipment") or with a factory installed flat or stake bed.
IMO: Pass! If this is an F350, it will have leaf spring front/rear suspension, will ride and steer like an oxcart. Only wheels available have 6 lugs on a 7.25" bolt circle.
Power steering was not available, cannot be swapped in from later trucks.
Need to see pics so we can see what you're looking at. If this truck has a pickup bed, it's a previous owners aftermarket conversion.
Old 04-18-2017, 08:22 PM
RangerMercMan's Avatar
RangerMercMan
RangerMercMan is offline
Originally Posted by 1972RedNeck
4.10's and direct drive? The MHP clocked me at 103 with the same setup. I think that's just a wee bit faster than 50 or 55...
Well you are admitting you pegged the speedo, are you also admitting to pegging the tach? Is your speedo accurate?
Old 04-19-2017, 09:33 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
With or without power brakes?
Old 04-20-2017, 10:03 AM
Amish65F100's Avatar
Amish65F100
Amish65F100 is offline
I'd keep it just the way it is. Looks like a nice truck and the dual wheels gives it some character.
Old 04-22-2017, 04:28 PM
1972RedNeck
I would guess that the speedometer was about 10 over 100 so it's not perfectly accurate. I was taching a touch over 4500 and I did have a bit pedal left.
Nowadays I have to keep it under 80 as I still haven't figured out my nasty driveline vibration that comes in at about 78 since I swapped the NP205 in.
Old 04-22-2017, 07:51 PM
RangerMercMan
Well back in the early 90s when I was a greenhorn I just completed a fuel injection course and was assigned to a GM garage. It was only for a couple of weeks just for some field experience and they were having difficulties with a 1 ton Dooley truck there they had for six months in the shop and could not figure out the problem with a bad vibration. I got lucky maybe but I spent less than two minutes looking at it and said either the drum is out of round or the axle is warped. The mechanic looked at me and said how the heck did you come up with that conclusion and I said well look at it. A new drum and the problem was solved.
Old 04-22-2017, 10:17 PM
1972RedNeck
I think mine has to do with my rear pinion angle being way out of wack. I just haven't got around to building shims for it yet.
Old 05-06-2018, 04:50 PM
twinrotors's Avatar
twinrotors
twinrotors is offline
Has power brakes
1957F350
05-14-2018 11:27 AM
thebigtruck
04-09-2018 07:20 AM
blisstruck
06-23-2013 10:58 PM
fordf350camper
21
10-03-2012 06:38 PM
freakboy
11-28-2009 07:44 AM
Quick Reply: 1966 question?
