Is there a trick to removing interior windshield trim?
Only reason I was trying to remove it is I need to remove the A pillar trim and it's tucked underneath it.
Mine was help on by some stiff metal clips that are attached to the trim piece. I carefully and firmly pulled down on about 1/3 of it at a time, slowly moving across the windshield, and the clips popped out. My truck has a headliner and I don't know if they are different. Mine also has one along the top of the rear window. I had to remove them to replace the weatherstripping on the doors.
1980/86 F100/350 & Bronco:
EOTZ-1003606-A .. Windshield Upper Garnish Moulding - Use with or without headliner - Paint to match / Obsolete
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
HIGH BUCK! BOB ALLEN FORD in Overland Park KS has 3 = 913-381-2999.
4) EOTZ-1003552-A .. Retainer - Upper Windshield Garnish Moulding - Use without headliner / Obsolete
GREEN SALES CO. has 37.
4) EOTZ-1303552-A .. Retainer - Upper Windshield Garnish Moulding - Use with headliner / Obsolete
GREEN SALES CO. has 28.
I can tell you it is a pain, them clips really hold it on there.
I was lucky my parts truck was a roll over and I could see how it was installed so I could remove it from my project.
Now this was a wile ago and don't remember how I did it but I will try and find the moldings and get a picture as that may help.
Dave ----
Edit for pictures:
This is from the roll over truck but think got bent trying to remove it which is sad because the project truck one has holes drilled in it.
I think I might be able to get it straight but I also have a over head shelf from the roll over truck that I think will hide the molding.
As can be seen it has 4 clips and they can be a pain. I cant remember how I got it off but want to say I used 2 flat blade screw drivers to pry on either side.
Dave ----
Edit for pictures:
AbandonedBronco
1978 - 1996 Big Bronco
10-25-2015 07:40 PM
alvald83
07-13-2010 12:48 AM
girlwithatruck
27
07-28-2009 07:47 AM
