Do I need to add oil to my A/C system?
Old 07-13-2016, 07:19 PM
velcro7279's Avatar
velcro7279
velcro7279 is offline
I have a 1994 F 350 that the A/C isn't cooling as well as it should. I know this is r134. I have a manifold set for the A/C that I have used before on other vehicles, so I know how to add the refrigerant. I need to know if I need oil for it before I hook up the gauges to add refrigerant. I saw a TSB about insufficient oil in these systems. That is why I am asking about this.
Old 07-13-2016, 07:30 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Any leak in the AC system can take compressor oil with it, so it's always a good idea to replenish the compressor oil if you're charging it.
Old 07-13-2016, 07:45 PM
velcro7279's Avatar
velcro7279
Any idea how much I should add? I have seen where these can take 9 oz if they are empty, but not sure what to add at this point.
Old 07-13-2016, 09:15 PM
Lead Head's Avatar
Lead Head
Unfortunately I have no idea how much you should add, and it can he hard to judge depending on the type of leak.
Old 07-20-2016, 08:11 AM
ASTROENG2011's Avatar
ASTROENG2011
ASTROENG2011 is offline
You should be ok adding one of the pressurized cans available at the auto shops. It only holds 2 oz of oil. Make sure to add the correct type of oil. PAG used in almost all of the r-134a systems is very finicky about mixing with other types( POE maybe, but definitely not mineral). PAG comes in different viscosities. PAG100 and PAG46 are two that are avaialable. Check your owners manual for correct identification. Use proper care and precaution when adding the oil so as to not add any trapped air in the hoses.
Old 07-20-2016, 08:58 AM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
1994 calls for 7oz of PAG 46 oil.
Old 07-21-2016, 06:44 PM
velcro7279's Avatar
velcro7279
Thanks for the info guys. Ill get some PAG 46 for it and add a little when I put in the refrigerant.
Old 07-21-2016, 06:56 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
POE oil is fully compatible with all other types of oil in R134a systems, and it's much, MUCH cheaper.
garyd
1997 - 2003 F150
07-03-2017 05:57 PM
DaveBB
11-26-2013 11:55 PM
Gold Stripe
17
04-18-2012 08:48 PM
F-250 WARHORSE
07-08-2011 08:42 AM
GTEK
06-24-2010 10:54 PM
Quick Reply: Do I need to add oil to my A/C system?
