80/86 Factory Tachometer Help
Hello,
A gauge cluster with a tachometer is plug-and-play. All of the wires and connections already exists in the vehicle and are ready to go. All you have to do is find a gauge cluster with a tachometer and swap it in and you're done. This is also a good time to get a resetable tripometer if you want one. Otherwise, you can keep your current miles, etc. by swapping over your current gauges.
Main reason you can't just put a stock tach in your current dash is because the only difference between a tach and non-tach vehicle is the printed circuit board on the back of the cluster, and those are riveted on quite well.
xjpilot
03-20-2012 05:28 PM
Leonard Bode
12-03-2003 08:22 PM
