1979 F150 engine swap
I recently bought a RWD 1979 F-150 Ranger rolling chassis in very good condition. My plan is to build a nice 460 to put in it, but while I do that, I want to put in a smaller motor to putter around town in.
I happen have a 289 that came out of a 1965 Mustang , as well as a small block C6 that came out if a RWD 1977 F 150 behind a 302.
I know that 289s and 302s are virtually identical, so, theoretically, the 289 should bolt up to the C6, even though this motor/tranny combo never existed in production.
I think that's why I'm having a little trouble finding info for this swap. I also need to buy a flexplate for the 289, and since 289s only came in front of C4s, I'm worried about a stock Mustang flexplate being compatible with the C6. I also wonder if stock F150 302 flexplate would be the correct balance for the older 289.
Is what I'm planning possible? Or am I missing some insurmountable incompatibility that will doom my plan to failure?
Yeah, that's my #1 concern. If the stock '65 Mustang flexplate bolts up to the C6, I'll be golden. If not, I'll have a whole can of worms to contend with.
The first thing to check is the bellhousing bolt pattern. In mid -year 1965,Ford changed from a 5 bolt bellhousing to a 6 bolt. As long as you have a 6 bolt block the c-6 will bolt up. As for the flywheel I'm not sure if the 65 will bolt to the c-6, the bolt pattern of the converter studs may be different. If it is, the one for the 77 should work. I know Ford changed the balance on the 302,but I think it was in the mid 80's. Also, measure the pilot diameter of the converter and crank and make sure they are the same. The 65 could have had a c-4, or a cruise-o-matic,which was like an FMX.
Yeah, that's my error, this 77 C6 was behind a 351W, not a 302 (when I said I "have" the tranny, I meant it's sitting in my father's pole barn).
The six bolt Windsor pattern should still bolt up, and from the responses here and a little more digging, I think I could mate the two if I put a C6 flexplate from a 302/351W, with the matching torque converter bolt pattern, and a 28oz imbalance on the 289.
The only thing left I think is needing either a 164 or 157 tooth wheel. Have to get the transmission and do some research.
Thanks for the great responses so far.
a-stei34
18
06-29-2015 09:10 PM
400Nut
08-12-2006 11:37 AM
pat ellis
12-31-2003 01:26 PM
JoeBlow
03-23-2003 11:17 PM
