can this bolt up?
Old Mar 23, 2003 | 01:24 PM
JoeBlow's Avatar
JoeBlow
can this bolt up?
I have a 1979 F100 with a c4. I found a c6 off of a 1974 with a 300 inline 6. will it bolt up? what else do I need to make the swap happen?
thanks
Old Mar 23, 2003 | 01:36 PM
Boss_358's Avatar
Boss_358
can this bolt up?
What kind of engine is the your C4 bolted to. 302, 300-6?
Old Mar 23, 2003 | 01:37 PM
JoeBlow's Avatar
JoeBlow
can this bolt up?
302, duh. I can't believe i left that out.
thanks
Old Mar 23, 2003 | 01:42 PM
Boss_358's Avatar
Boss_358
can this bolt up?
The C6 should bolt up with no problems. You may have some tranny crossmember issues. But they should not be bad if there are any at all. You may or may not have to change your flexplate and use the one that goes to the C6. I have a C6 that came off of a 300-6 out of a 1982 Ford van which is bolted to a 302. I forgot exactly what I did but it works fine.
Old Mar 23, 2003 | 01:44 PM
JoeBlow's Avatar
JoeBlow
can this bolt up?
I'll get it tomorrow morning and try it. I figure I dont have much to lose for 50.99, with a 20 dollar core.
thanks alot
Old Mar 23, 2003 | 09:46 PM
StrangeRanger's Avatar
StrangeRanger
can this bolt up?
The <a href="http://motorhaven.autoanything.com/">302 </a>and 300 flex plates are balanced differently. You cannot use a 300 flexplate on a 302.
Old Mar 23, 2003 | 11:17 PM
AggiePSD's Avatar
AggiePSD
can this bolt up?
The crossmember will need to be moved back several inches or so and the driveshaft shortened. You'll then have to extend the shifter linkage and modify the kickdown linkage. Not to hard though, and worth the trouble.
crm318
Engine Swaps
21
Jun 26, 2015 09:31 AM
360F100
Jan 15, 2012 04:11 PM
angelblue23
Mar 7, 2009 10:55 PM
motordaddy
Aug 27, 2004 08:39 PM
Clay911
Mar 9, 2004 09:28 PM
