C4 vs c6 in 4.9l
Old Sep 8, 2018 | 04:16 AM
Miklman3477's Avatar
Miklman3477
C4 vs c6 in 4.9l
hey so I need to do an engine swap on the 4.9l engine. It is currently mated to a C6 transmission. I found an engine that was mated to a c4, will this work with my c6 trans? Or is the bolt pattern different?
Old Sep 8, 2018 | 11:49 AM
Conanski's Avatar
Conanski
The trans bolt pattern on these blocks never changed so you're good.
Old Sep 8, 2018 | 10:19 PM
baddad457's Avatar
baddad457
If you're doing a V8 swap like what you posted somewhere else, the flexplate for the six will not work. It's neutral balanced, the V8's are externally balanced and have a counterweight on the flexplate
Old Sep 9, 2018 | 12:19 AM
Miklman3477
What about is I found a 4.9 engine that had an e4od transmission? Would the bolt pattern be different on that?
Old Sep 9, 2018 | 09:25 AM
baddad457's Avatar
baddad457
Bolt patterns never changed.
a-stei34
18
Jun 29, 2015 09:10 PM
dieselkid
Modular V10 (6.8l)
Feb 1, 2012 01:27 PM
DPhillips
Apr 7, 2006 04:20 PM
mr greg
Oct 12, 2002 07:24 AM
