Oil/Trans Temp "combo" gauge??
Old 07-15-2016, 10:57 PM
finallyo3gt's Avatar
finallyo3gt
finallyo3gt is offline
Originally Posted by knottyrope
Did you choose the right communication type? Mine would only read RPM till I selected correct protocol.
I watched torque and my scan tool both cycle 4 or 5 protocols. My scan tool has a system test of some sort that makes a buch of relays click. But, I understand those tools are hit or miss. I'm more concerned that torque won't communicate, since it's generally accepted that it should. Fuse for OBD is good, voltage present, ect. I have I think 2 threads on that issue alone.
Maybe I could buy an interceptor from a vendor with good tech support and return policy..lol.
Old 07-16-2016, 02:25 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
I've read a few instances on the glowshift fuel pressure sending units not lasting long. Mine just quit a week or so ago and had less than 5000 miles on it. I bought an autometer gauge now. My glowshift trans temp gauge lasted 5 years before it bit the bullet. EGT gauge is still going after 6 years, and reads just about 25 less than my autometer does on the other side of the motor. Boost gauge worked, but I replaced as I didn't believe the boost numbers. Turns out it was right. Just an FYI. All these year measurements I give you are not a lot of miles. I only put on about 2500-3000 miles a year.
Old 07-16-2016, 04:08 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
Good conversation and info here. I think I'll add this thread to my "collection" of information threads.
Old 07-16-2016, 08:47 PM
finallyo3gt
What vendor do you guys recommend for the aeroforce? Aeroforce is very proud of their analog input accessories. Maybe just the interceptor, then a stand alone fuel psi and EGT gauge in a 3 gauge pod. Not really sure that'd be too much cheaper, but Aeroforce wants $100 for theamplifier and $65 for the probe. And $65 for the fuel sending unit.
2000V10USER
1999 to 2016 Super Duty
02-05-2022 11:03 AM
mikeyc0120
11-11-2011 10:48 AM
tommyl
12-23-2007 12:52 PM
460me
Oil & Lubrication
03-08-2006 06:00 PM
Quick Reply: Oil/Trans Temp "combo" gauge??
