1997 7.3 OBS died while driving. Won't start.
I have a 1997 F350 7.3 powerstroke with 360k. I have had issued in the past with it idling rough, but was able to move the wiring harness that goes to wires under valves and get it to quit. The other day I was driving and it just shut off. Like switching the key off. Got out, moved the wires, and it cranked back up. But once I arrived it would not start. Spins over strong and tried to hit but wouldn't run.
So I had it towed home and now can get it to turn over but won't hit at all. Tach is moving when it is cranked, checked the UVCH on both sides and they weren't burnt or apart. Oil is full, both tanks are full. Replaced the ICP sensor. Smoke comes out of tailpipe when I turn it over. Will hit on starting fluid but won't remain running. New fuel filter, fuel bowl is full. Not sure where else to turn. Any help would be great. Thanks.
X2 on this. Plus if the compression is a little weak, it would compound the problem. Make sure the GP system is in top shape.
So a little update on what I've been trying. tried the block heater for a couple hours, nothing. Ordered a new IDM and still the same thing after replacing it. But had 2 new codes pop up after replacing the IDM. First was P1283 injector high side open. Second was p1298 IDM failure.
Would this point to perhaps a shorted wire along the injector harness not allowing the IDM to get signal to injectors?
malibusnyder
06-30-2017 01:29 PM
dumptruck denny
60
02-14-2015 06:53 AM
blackbettybam-a-lam
38
08-12-2012 08:26 AM
quality1construction
79
03-03-2008 08:12 PM
