Engine Missing
#46
I have the meter set on the 200 volts dc setting.
Should there be dc voltage on the 2 pins next to the center common, they actually hook to the injectors don't they?
Thanks RB
#47
I'm going to try this on mine in a few minutes.
#48
the readings I put in the post was the center (female) on the plug where it plugs into the VCG to ground.
Thanks RB
#49
I was about to then pool filter was clogged. Too me a while to clean the tubes and reseal. Tomorrow is another day.
#50
Well I have ohmed out the L&R bank power feed to all the injectors, they were 3.2 or 3.3 ohms. The range is 2.8 to 3.6 ohms
L&R bank power feed to IDM ground circuit it was open.
L&R bank power feed to injector ground shield it was open.
So at this point I would think it is the IDM?
Thanks RB
Thanks RB
#52
#53
glad you are up and running again
I used a meter on my UVCH while truck was running and cant see the 110v as it is isolated to ground but when using meter across the coil output I could only see the pulses but not measure it. an oscilloscope could be used but not many have one of those. I might go dig mine out just for fun some night
KLONDON
16
10-05-2016 04:15 PM
78fordman
10-15-2007 07:04 PM
